Moving an object, relative to another object
Could you please let me know if there is a way of moving an object parallel to a specified line etc.
Re: Moving an object, relative to another object
Parallel (through) LG? Then delete construction line.
Windows 10
If you choose the reference point on the line, then click another point on the same line. That should do it.
JJ Win7 pro-64
Also OG works... each (LG and OH) require a construction line before the actual move. I'm sure there's an easier way though.
edit: accidentally type "OG", not "OH".
Windows 10
