Hi everyone,
Thank you for hosting this forum. I will try and describe my problem as best I can in the hopes someone has had a similar issue (and a solution).
QCAD version:
./qcad -platform offscreen
QCAD version 3.26.1
uname -m
x86_64
I've downloaded the following file https://qcad.org/archives/qcad/qcadcam- ... x86_64.run from https://qcad.org/en/download
I use Docker to spin up (albeit temporary) servers. I use a PHP-CLI user (non-root) as default via docker-compose. The following command is used to execute commands inside Docker:
docker-compose exec php-cli bash
I've ran the following command as non-root user without it actually creating a PDF file:
./dwg2pdf -a -c -k -f -platform offscreen /path/to/file.dwg
How can I run the (trial) program to successfully create a PDF file as a non-root user?
Thank you for your time.
Tom de Wit
