Imorting DXF file
Clifferator
Imorting DXF file
Post by Clifferator » Sun Mar 14, 2021 7:03 am
Hi all
I have made a template with an origin of 0,0. I need to import a land surveying DXF file whose origin is (say) 100000, 300000. If I import the file the template disappears, can anyone tell me what I'm doing wrong?
Cheers
Re: Imorting DXF file
Post by andrew » Tue Mar 16, 2021 10:08 am
One would typically load the surveying DXF (model space) and then switch to a layout block and add the title block and border there (paper space). Then add a viewport to the layout block. A viewport is a "window" that shows (part of) your surveying DXF drawing.
For more on layout blocks and viewports, please refer to our tutorial at:
https://qcad.org/en/tutorial-working-wi ... -viewports
