Hi Andrew
I seem to have a problem, I cannot log in as John Hyslop even though I've logged in before.
Any idea what could be causing this?
I was trying to Vote on a request logged by CVH.
Thanks in advance
Cheers
John Hyslop
[SOLVED] Cannot Vote on bug tracker?
- Premier Member
- Screenshot_20210314_101950.jpg (135.14 KiB) Viewed 2669 times
Re: Cannot Vote on bug tracker?
Your user name for the bug tracker is:
johnhyslop
johnhyslop
- petevick
- Premier Member
"johnhyslop"
Pete Vickerstaff
- Premier Member
[ SOLVED ] Cannot Vote on bug tracker?
Hi Andrew
How embarrassing thank you for confirming my user name for some reason Firefox had my user name saved as John Hyslop
the same as Qcad Forum, I'm assuming at the time I saved the password in Firefox and then discovered that the bug tracker doesn't
except user names with a space like it does on this forum.. is that right ????
Anyway many thanks
Cheers
John
PS Thanks for the moral support Pete
Anyway many thanks
Cheers
John
