Hotkey to minimize QCAD
Post by andrew » Thu Mar 11, 2021 8:36 am
From a QCAD user:
Is there a hotkey to minimize the QCAD application window?
Re: Hotkey to minimize QCAD
Post by andrew » Thu Mar 11, 2021 8:39 am
Under Windows (for all applications):
Windows-Key + Down arrow
macOS (for all applications):
Command-M
Linux (for all applications):
Ubuntu >= 12: Ctrl-Alt-0 (on the numeric keypad) or configured hotkey
Others: depends on the distribution, window manager and user configuration, please use an Internet search engine to search for the default hotkey for your setup.
Post by Husky » Thu Mar 11, 2021 10:45 am
Maybe worth to mention ...
Windows has 3 standard sizes for Program windows ...
1. Maximized
2. Restore down (last remembered size between Maximized and Minimized
3. Minimized
... what means to minimized a maximized program window you have to use Windows-Key + Down arrow TWO times.
If you prefer to minimize it in just one step you can use Alt+Space+n
