[solved]Copy with reference
hencca
Post by hencca » Mon Mar 08, 2021 8:13 pm
Hello!
I am using QCAD Professional 3.26.0.0 with Windows 10 Pro.
When using Copy with reference and then Paste the reult is a dot that consists of all the original entities but all you can see on screen is a dot. The command has worked proprly before and i dont know what caused the problem. I would be glad if you have a solution.
Hencca
Nasev_1k_ark.dwg
(74.18 KiB) Downloaded 281 times
Re: Copy with reference
Post by andrew » Mon Mar 08, 2021 8:35 pm
You might be scaling by a very small factor while pasting. Please check the scale factor in the options toolbar while pasting.
