Outer dimensions in Qcad.
Wujin
Post by Wujin » Mon Mar 08, 2021 12:56 pm
Hey!
I'm not very experienced Qcad user and I have a problem with dimensioning. My drawing looks as follows:
I'd like it to look in this way:
How can I change it?
Windows, Qcad version : 3.26
Re: Outer dimensions in Qcad.
Post by andrew » Mon Mar 08, 2021 1:00 pm
Moving the dimension label
Select the dimension, then drag the text label using its blue reference point with the mouse.
Arrows on the outside
View > Property Editor
Change the properties "Flip First Arrow" and "Flip Second Arrow" to "yes".
Wujin
Post by Wujin » Mon Mar 08, 2021 1:32 pm
Thank you. I couldn't flip arrows individually, but I clicked circle inside of one arrow and it worked.
Post by andrew » Mon Mar 08, 2021 1:49 pm
Please attach your drawing file. Feel free to reduce it to the dimension with that problem.
