break/interruption line
Giuliano69
Post by Giuliano69 » Sun Feb 28, 2021 6:52 pm
Is it possible in Qcad PRO to automatically generate/draw a break/interruption line like this ?
petevick
Re: break/interruption line
Post by petevick » Sun Feb 28, 2021 7:04 pm
I'm pretty sure there is no tool to do that, but it's probably something that a script could manage
...or maybe use a block ??
Pete Vickerstaff
Post by Husky » Sun Feb 28, 2021 7:26 pm
No, not to my knowledge. I think petevick suggestion is the best way to go ...
Giuliano69
Post by Giuliano69 » Sun Feb 28, 2021 11:58 pm
It seems that, for such an intended use, Qcad would prefer the "free hand tool" instead of such "canonical" sign....
BTW
with the block solution, we could choose as reference the center of the block, and stretch/shrink as needed.
But it requires to calculate the average point between to lines. One more operation...
The "automatic/script" solution, would ask the first point, the second point, and then scale the sign as needed automatically.
If implemented "natively", this second solution should be more useful...
BR
petevick
Post by petevick » Fri Mar 05, 2021 10:19 am
Have a look here -> viewtopic.php?f=30&t=8204 Hopefully that should meet your needs. As noted, I already have thoughts on improving it :roll:
Pete Vickerstaff
