I find that I have a lot of zero length objects after drawing for a while. Not sure if it is operator error or a peculiarity of QCAD.
Does trimming lines cause zero length objects?
Any advice would be appreciated.
Learn What Causes Zero Length Objects (Solved)
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Re: Learn What Causes Zero Length Objects
I think that chamfer set with a zero chamfer distance causes a zero length object. Trim Both does not.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Never noticed ...
I myself have so few problems with zero entities that I couldn't even say what caused them. Most of the time I see them in drawings that have been imported from other CAD programs to QCAD ...
