First I draw a circle and dimension it with the diametric (DD) tool. If I change the circle diameter in the property editor, the dimension doesn't change in any way. I get the same result if I scale (SZ) the circle while retaining its center point.
Hence, I wonder if QCAD has associative dimensions.
QCAD 3.25.2
Windows 7 Pro
Thanks,
Don C.
Does QCAD have associative dimensions?
- petevick
- Premier Member
Re: Does QCAD have associative dimensions?
it kinda does, if you use stretch to move the end of a dimensioned line, making sure to included the end of the dimension, the dimension is stretched with the line giving a true dimension, probably won't work with a circle though.
Pete Vickerstaff
