[solved]- Merging/grouping polyline
I converted a PDF to DXF so I can cut the project out on my CNC rather than using a hand jig saw. The perimeter of each part is thousands of small lines. Is it possible to group/merge the pieces to one line?
Re: Merging/grouping polyline
Try to convert to a polyline with "Polyline from Segments (OG) or Polyline from Selection (OC)".
Re: SOLVED - Merging/grouping polyline
You are awesome. THANK YOU
