Whiteout (Solved)
seasdes
Senior Member
Whiteout (Solved)
Post by seasdes » Tue Feb 16, 2021 6:20 am
I need to insert some text over some linework and images. In some other CAD packages there is a whiteout function that allows this to happen. Is it possible in QCAD?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Whiteout
Post by Husky » Tue Feb 16, 2021 8:45 am
QCAD does not have a whiteout function. This said, you can use a solid hatch to have a similar effect.
seasdes
Senior Member
Re: Whiteout
Post by seasdes » Tue Feb 16, 2021 9:01 am
Thanks Husky.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
John Hyslop
Re: Whiteout (Solved)
Post by John Hyslop » Thu Mar 24, 2022 5:20 am
Hi
This is a bit of a hack but it works e_surprised
I draw white on a black screen and I thought I'd share this with you all...
It's just a white image but you can change its size width & height as you like, I hope this comes as a handy tip..
Just make sure Modify > Draw Order > Bring to Front is set or use hotkeys MF :D
And once you have in your drawing you can cut and paste as you like.. :wink:
The Whiteout.png file..
WhiteOut.zip
(278 Bytes) Downloaded 261 times
Cheers
John Hyslop
John Hyslop
Post by John Hyslop » Thu Mar 24, 2022 6:52 am
And Why not have a round one too :D
That can be made oval or any size you like..
WhiteoutRound.png.zip
(2.9 KiB) Downloaded 255 times
Cheers
John
seasdes
Senior Member
Post by seasdes » Thu Mar 24, 2022 7:01 am
Thanks John. A great tip. And the image size can be reshaped by dragging the handles of the image. :D
seasdes
QCAD Pro V3.27.8
User since 2021
W10
John Hyslop
Post by John Hyslop » Thu Mar 24, 2022 8:38 am
Thanks seasdes
Here's another whiteout, square with radius corners...
WhiteoutSqrRad.png.zip
(1.14 KiB) Downloaded 275 times
Cheers
John Hyslop
