Possible to import an SVG file like the following, and preserve the text?
https://www.dropbox.com/s/3toa1rg48gtyh ... s.svg?dl=0
Import SVG and preserve text
Re: Import SVG and preserve text
No. Text is currently not imported from SVG (only geometry).
Luckily SVG is a open standard so if you needed to do this often it could probably be done for plain text stripping out fonts etc.Theoryshaw wrote: ↑Wed Feb 03, 2021 8:21 pmPossible to import an SVG file like the following, and preserve the text?
However once you get into all the rendering options SVG can do that would take a bit more coding.
https://developer.mozilla.org/en-US/doc ... ement/text
Comments based on Version: 3.26.2 unless otherwise noted.
