Import SVG and preserve text
Theoryshaw
Post by Theoryshaw » Wed Feb 03, 2021 8:21 pm
Possible to import an SVG file like the following, and preserve the text?
https://www.dropbox.com/s/3toa1rg48gtyh ... s.svg?dl=0
Re: Import SVG and preserve text
Post by andrew » Wed Feb 03, 2021 8:34 pm
No. Text is currently not imported from SVG (only geometry).
turtle
Post by turtle » Mon Feb 08, 2021 5:19 pm
Luckily SVG is a open standard so if you needed to do this often it could probably be done for plain text stripping out fonts etc.
However once you get into all the rendering options SVG can do that would take a bit more coding.
https://developer.mozilla.org/en-US/doc ... ement/text
Comments based on Version: 3.26.2 unless otherwise noted.
