Again, hello.
Has anyone successfully imported the RAL colour palette into QCAD?
Or know how to use these colours?
Thanks again,
Alec
Importing and using RAL colours - SOLVED
- Junior Member
Re: Importing and using RAL colours
The current snapshot release 3.25.2.11 comes with a customizable color palette.
Snapshot releases are not intended for production use. This will very likely also make it into the next stable release.
Yes.vettawindows wrote: ↑Sun Jan 31, 2021 6:07 pmHas anyone successfully imported the RAL colour palette into QCAD?
Also Yes.
Once:
1. open Application Preferences
2. General / Color Palette / Insert RAL Colors
From now on:
3. Use RAL Colors in every Color related Selection Menu
@Andrew: By the way, colors is a very complicated issue.
E.g.: In QCAD the predefined color for RAL 1003 is #F7BA0B
On http://farbenfinder.de/RAL1003 the color is #F9A800
On https://de.ralcolor.net/signalgelb.php RAL1003 is #E5BE01
What is the right color definition?
Sure, I can change it individually in Application Preferences or in QCAD3.ini but that seems not to be the right way because RAL should be a standard. Isn't it?
Our source was: https://www.w3schools.com/colors/colors_ral.asp
As far as I know there are no official RGB codes for RAL colors, only approximations. Indeed a "very complicated issue" as you sayThere can only be one right but which is it?
Thats true but I was astonished how much the RAL colors differ from source to source. Not only in numbers but visible.
How ever, I found under http://ralcolores.mrket.net/indexD.php?index=RAL_UP a list of RAL definitions in german.
Feel free to use it.
The use of RAL color palettes is restricted by its license. We will provide a .gpl palette file import instead in the preference dialog and include some free palette files. Licensed users of the RAL palette can also import RAL colors this way.
- Junior Member
Thank you all. I will mark this as SOLVED
