How to distinguish better the enabled or disabled state in QCAD dark Mode?
Post by CVH » Fri Jan 22, 2021 2:38 pm
There was reported an issue with FlexPainter ....
That one couldn't figure out how to set certain options.
Or that one can't see certain thing clear
In Dark Mode:
In Normal Mode:
All rather obvious in Normal Mode ...
Found no scripting solutions with QWidgets palette nor with QWidgets stylesheet.
DarkMode supersedes that what can be altered with scripts.
Stick to Normal.
