I'm noew to qcad - so please forgive my ignorance if this is a stupid question.
I have a 2d drawing from which i'd like to get the area/surface masuerements.
I understand there is a polyline/polygonal funtion in the information tool section. To be honest, i havent fiegured out how to apply those tool - Do i have to select each line/point manualy (which would be quite a PITA) ? Is there a simple(r) method?
thx in adavance
Version: 3.25.2.0 (3.25.2)
Build Date: Sep 4 2020
OS: Win 10
Surface/Area measurements
Re: Surface/Area measurements
Which areas are you looking for?
Would it be possible to post the dxf?
thx for your reply.
Well, i'm lookung for the area between the most outer cyan line and the inner, dark blue line - minus the cyan and blue "holes"....
Please find the dxf attached. I "restructered" into 3 layers (outer, inner, cut-outs) to make it more clear.
- disc2.dxf
- (140.92 KiB) Downloaded 385 times
Ok, thanks. QCAD will help you with the math but will not do the entire calculation for you ...
You need: Change some entity styles, the Property Editor, a Pocket calculator
How I would solve it ...
Select and convert all shapes to polyline with OG or OC,
select blue circle - move them temp. to Layer "Cut outs",
Select Layer "Outer" - write down the Total Area from the "Property Editor",
Select Layer "Inner" - write down the Total Area from the "Property Editor",
Select Layer "Cut outs" - write down the Total Area from the "Property Editor",
Use a Pocket calculator etc. to do the math (1-2-3) ...
thx - that helped a lot.
Maybe that would be a feature for a feature relase
thx again
thx again
Filed Feature Request.
https://www.ribbonsoft.com/bugtracker/i ... sk_id=2180
Andrew won't implement that.
https://qcad.org/bugtracker/index.php?d ... ask_id=116
