Custom Script Directory?
marcelrg
Post by marcelrg » Fri Nov 27, 2020 10:02 pm
When I'm writing custom scripts is there a path that I can save them to other then
C:\Program Files\QCAD\scripts\Misc\Examples
I would like to install my scripts in a directory off my homedir and have QCAD automatically add my scripts to the menu?
Re: Custom Script Directory?
Post by CVH » Sat Nov 28, 2020 6:00 am
Assuming that you are a win user.
True, it can be annoying that windows interfere when it protects the OS portion.
I write, develop and debug my code with NPP in admin mode.
It works fine and on top NPP opens with everything the way I left it.
In a way we can:
- 'other than e.g. C:\Program Files\QCAD\scripts\Misc\Examples'
- 'install my scripts in a directory off my homedir'
- 'have QCAD automatically add my scripts to the menu'
But there are some basic concepts one has to obey.
First read:
https://www.ribbonsoft.com/en/tutorial- ... pt-actions
https://www.qcad.org/doc/qcad/3.0/devel ... rials.html
So, for a script to be added automatically to the menu:
- we need at least the folder structure under the script folder.
- with a minimal part of code explained in the tutorials.
- with an '.init' section to add them (automatically) to the menus.
To run custom code from outside the installation folder:
- 'include' the custom scripts in their folders or homedir at the top
- call the scripts, methods, functions.....
There is an example of one add on script I made on the fly:
https://qcad.org/rsforum/viewtopic.php?f=30&t=7497
One could migrate the core code itself to anywhere as long as we include a path to it.
There is much more on the Forum e.g.:
https://qcad.org/rsforum/viewtopic.php?f=32&t=6668
2 words of advice by Andrew:
- Start small and build up. :wink:
- The debugger mode is not intended for production use of QCAD :!:
(The last link explains my two shortcuts on the destop)
Hope this helps
Post by andrew » Mon Nov 30, 2020 9:53 am
You can add scripts to a "scripts" folder inside the folder returned by RSettings.getDataLocation().
Here that would be:
C:/Users/andrew/AppData/Local/QCAD/QCAD/scripts
