Hi Everybody,
is there a possibility to open the Qt Script Debugger not only if an error in a script occurred but before. I would need it to debug my scripts, even if there is no obvious error in the script. The debugger is also good for developement e.g. to see the order in which the event handlers are called a.s.o.
Open Qt Script Debugger not only if an error occurred
Re: Open Qt Script Debugger not only if an error occurred
Thanks. That's what i was looking for. I wanted to determine which script and at which point i want to debug the script in the Qt Script debugger.
Is there a way to print out strings / variable values to the console or the debugger output. something like System.out.println() in Java ?
qDebug does not work, print or alert doesn´t work too.
fakeuser,
Read the forum rules ...
1Q/Topic pls
Windows? No qDebug.
Did you try to search the forum for 'qDebug' ?
To the command line works.
1Q/Topic pls
Windows? No qDebug.
