How to delete multiple layers quickly?
Re: How to delete multiple layers quickly?
1. Mark the layers to be deleted in the layer list
2. Right click
3. Delete layer "YR"
Thomas
PS:
Mark layers with SHIFT or CTRL / CMD
2. Right click
Thomas
PS:
One can simply type 'YR' too.
This does not work if you are in the layer list (which you are automatically in when you mark the layers to be deleted).
So right click and select "yr" is the better way.
Thomas
Hi Thomas,
Windows7 32 bit:
Did try it out several ways. Even with the layer list floating.
Selecting multiple layers with Ctrl or Shift and type 'YR' works for me ... every time.
What doesn't turn out correct is the right-click when not on a selected layer.
That changes the selection and one can start over.
The reason I use YR after spitting through a layer list.
Windows7 32 bit:
I tested it in QCAD 3.25.2 on windows 10, 32 bit and "YR" works as you say there.
Under macOS it only works if you are not in the layer list.
Perhaps Andrew can correct this, but I'm afraid it will come back to a "bug with Qt".
Anyway, it's not dramatic as the right click and delete works fine on both Windows and macOS.
Thomas
Thomas
Thanks, Thomas:
If he doesn't pick this up, I'll report it.
TSG: Please check your preferences on macOS:
Edit > Application Preferences > General > Keyboard > Enable keyboard navigation in list widgets
If this preference is checked, you can use arrow keys or type starting letters to navigate the layer list and block list. Downside: key codes don't work if a list has the keyboard focus.
Not set here,
Nice formulation of pro/con to include on a tooltip.
checked: "YR" doesn't work.
unchecked: "YR" works as expected but no more navigation with arrow keys.
Thomas
Thomas
if checked: navigation with arrow keys is possible, "YR" isn'tIf this preference is checked, you can use arrow keys or type starting letters to navigate the layer list and block list. Downside: key codes don't work if a list has the keyboard focus.
if not checked: no navigation but "YR" works.
Thomas
I forgot: is it possible to correct this in QCAD-macOS so that the behavior is the same like in QCAD-windows?
Thomas
Thomas
As far as I can tell, it is the same as on Windows: You have to choose between keyboard navigation in lists or working shortcuts when operating lists. This is expected behavior.
Thomas,
From what I can read above the behavior is the same.
Mine was/is not set, unchecked. Typing = command.
I deleted the QCAD3.ini on both systems and what can I say:
the installations under Windows and macOS behave in the same way.
"Enable keyboard navigation in list widgets" is unchecked:
-> no navigation with arrow keys
-> YR deletes marked layer
-> any other letter doesn't do nothing (I love double negations)
"Enable keyboard navigation in list widgets" is checked:
-> navigation with arrow keys is possible
-> YR does nothing
-> first letter of layer name jumps to that layer
I would prefer if
-> any other letter does nothing
But there ist still my right click
Thomas
-> YR does nothing
I would prefer if
Thomas
