Scale in the viewport (solved)
Roberto Vid
Post by Roberto Vid » Wed Oct 21, 2020 4:46 pm
Hi, Could someone tell me how to work with the scale in the viewport. As an example, I need a detail with a 1:20 scale, I tried this and other scales, but I couldn't get a result. I appreciate the help. Thank you.
Re: Scale in the viewport
Post by Husky » Wed Oct 21, 2020 7:28 pm
Asking the same question again and again and ignoring our answers will bring you nowhere! What is wrong with our hints how to solve the task?
Roberto Vid
Post by Roberto Vid » Sat Oct 24, 2020 2:25 pm
Hi Husky,
Solved with the tips provided. Unfortunately, I didn't understand.
Thank you
Regards
