I recently installed the Pro Version and this is the first time I have checked for Updates.
I havedownloaded the latest 64 bit version in both tar.gz and .run formats into my downloads folder.
I would like instructions on the simplest way to install the upgrade.
My current version is located in my /home/Ironfighter/opt/ folder.
Your help will be appreciated.
System: Host: <filter> Kernel: 4.19.0-6-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19.0-6-amd64
root=UUID=ba0d8bf0-63e8-4306-9a6a-8e8a9cd8ed8f ro quiet splash
Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
Distro: MX-19.2_x64 patito feo February 15 2020 base: Debian GNU/Linux 10 (buster)
Machine: Type: Laptop System: LENOVO product: 20C6A010AU v: ThinkPad Edge E540
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20C6A010AU v: 0B98405 STD serial: <filter> UEFI: LENOVO
v: J9ETA2WW (2.28 ) date: 06/20/2018
Battery: ID-1: BAT0 charge: 40.0 Wh condition: 40.0/56.2 Wh (71%) volts: 12.4/11.2
model: SMP LNV-45N1 type: Li-ion serial: <filter> status: Not charging
CPU: Topology: Dual Core model: Intel Core i3-4000M bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19157
Speed: 798 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
Vulnerabilities: Type: itlb_multihit status: KVM: Split huge pages
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: mds mitigation: Clear CPU buffers; SMT vulnerable
Type: meltdown mitigation: PTI
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
STIBP: conditional, RSB filling
Type: tsx_async_abort status: Not affected
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0416
Display: x11 server: X.Org 1.20.4 driver: intel
resolution: 1366x768~60Hz, 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.3.6 compat-v: 3.0
direct render: Yes
