Changing Qcad theme
Changing Qcad theme
Qcad version: 3.24.3.0
OS: Ubuntu 16.04
Just started using Qcad and want to chang the theme from Light to Dark but can not find
the option on any of the Preferences can someone show me how to.
Thank you
OS: Ubuntu 16.04
Thank you
Re: Changing Qcad theme
Edit > Application Preferences > General > Theme
Getting blind
Thanks andrew
Thanks andrew
QCAD version 3.25.2, windows10
Same question.
Only 2 choices in application preference/general/theme: default or black
But default is black ! How to get some other color (white, grey, etc...)
Thank's for help
Same question.
Thank's for help
Same answer:
There is the general theme and there is the dark theme.
One has to reload Qcad to see the changes.
Perhaps you are referring to the drawing background in those themes.
Regards
Regards
To change drawing background: application preference>view>colors
Thank's for your help
- Active Member
I must be blind, I cannot find the option to change the theme under
As you can see on the screenshot, there is no such entry in the menu and the “Filter” box returns nothing when searching for the keywords “Theme”, “Light” or “Dark”.Edit > Application Preferences > General > Theme
You’re on macOS. Themes are not supported on this system.
- Premier Member
Hi Lumaja
If you are interested in playing around with theme colours, user Petevick made an application that can create custom themes, you'll find it here..
https://qcad.org/rsforum/viewtopic.php?t=8328&start=30
Cheers
John Hyslop
Cheers
John Hyslop
- Active Member
It's good to know that themes are not supported by macOS.
But my real question is not about themes but about the toolbar color. During the installation of QCAD, I chose a setting that made my toolbar dark and now I can't go back to light colors.
Can you tell me where I can find the setting to change the toolbar to light colors?
- qcad-toolbar-color.png (223.05 KiB) Viewed 6948 times
Please reset your QCAD configuration:
- Active Member
Thank you for your answer. Unfortunately it didn't work, my toolbar is still dark.
Also, there is a bug in the dialog box when QCAD asks for the settings at the first start. The background is completely black and it makes the captions impossible to read.
This looks like you might have installed a package that does not match your operating system. Please indicate what exact macOS version you are using and which QCAD package (file name) you have installed.
I'm unable to reproduce this here on the same system (macOS 12.3.1, M1) with the same QCAD package. There must be some kind of setting or preference that is different on your installation but I couldn't figure out what it might be. What are your settings for light / dark mode in your macOS System Preferences > General?
