text for laser engraving
andybics
Post by andybics » Thu Aug 13, 2020 4:37 am
Hi We use two software packages for laser engraving.
These are Autolaser and RDworks.
I cannot import text from QCAD dxf files into Autolaser and in RD works it contains the text info as well as the text.
Both programs work fine if I have multiline text in AutoCAD generated dxf files.
Can you help.
Andy
Re: text for laser engraving
Post by Husky » Thu Aug 13, 2020 4:54 am
which dxf version (R32, R27, R24 etc.) is used by you in QCAD? Which uppermost dxf version can be read by the other Software?
