Hi All
Can anyone help me here please?
I can't remember when this started happening but I would like to know how I can turn this off..
It appears to display the distance from the last point..
Cheers
John Hyslop
PS QCAD/CAM Version 3.24.3 March 17 2020 : Win10 64bit
[solved] Green Coordinate Text ?
- Premier Member
- What is This.jpg (43.44 KiB) Viewed 4236 times
Re: Green Coordinate Text ?
That is triggered by the Function Key "F8" on your Keyboard ...
It is a multi mode switch - hit it multiple times until it suits your needs.
- Premier Member
Thanks Husky
I've got a bad habit of hitting F8 to go into Ortho mod.. from Acad use lol
Cheers
John
Cheers
John
Nice! However must move the pointer to see update as just pressing F8 will not change display until pointer moved. (A suggestion?)
Best
Best
Windows 10
OT:
After a few sleepless nights I gave this to my Problemsolver department so that they can come up with a permanent solution. Now I know why I have to pay them so much every month - they found the solution immediately:
Use a double sided tape and add a Thump tack upside down on the F8 key. My team anticipate that your bad habit will be permanently broken with the next attempt to use F8 ...
AC user: Feel free to adopt this solution - it's free of charge!
OT end.
I was thinking about this ....John Hyslop wrote: ↑Sat Aug 08, 2020 9:24 amI've got a bad habit of hitting F8 to go into Ortho mod.. from Acad use lol
OT end.
- Premier Member
Re: [solved] Green Coordinate Text ?
Done...
