Accessing RGB values of RColor object
ScottP
Post by ScottP » Fri Jul 31, 2020 10:13 pm
How can I access each R,G,B value spanning 0 to 255 from an RColor object returned by getColor(REntity)? The API shows that RColor objects can contain R,G,B,A integers, or QString objects, or QColor objects. How can I force interpretation of the object as R,G,B,A integers?
My task is to find & store the RGB values of all uniquely colored entities from a document, like this:
aColor = [0,0,0,255];//RGBA black is always present
uniqueColors = [aColor];//javascript does not directly support multidimensional arrays
allEntityIds = document.queryAllEntities();
for(var e = 0; e < allEntityIds.length; e++){
	var entity = queryEntity(allEntityIds[e]);
	var color = entity.getColor(); //hoping to get colors as a 4-element array for R,G,B,A
	var uniqueColor = true;
	for(var c = 0; c < e; c++){
		if(color == uniqueColors[c]){ // uniqueColors is a 4-element array for R,G,B,A
			uniqueColor = false;
	if(uniqueColor){
		uniqueColors.push([color[0], color[1], color[2], color[3]]);// need to access RGBA values
Re: Accessing RGB values of RColor object
Post by andrew » Sat Aug 01, 2020 10:20 am
You can use:
color.red()
color.green()
color.blue()
color.alpha()
See also:
RColor API (derrived from QColor)
QColor API
ScottP
Post by ScottP » Wed Aug 05, 2020 12:43 am
Easy, thanks!
