What Commands Can be Pasted into the command line?
Re: What Commands Can be Pasted into the command line?
Looking into this with a windows version of QCAD, I've discovered the problem is with 'SELECTALL' in file 'Qcad Run Commands.txt'.
SELECTALL takes so long to complete that the copy command has been and gone before SELECTALL has finished. I don't know of any way to pause or halt QCAD, so the solution is to delete everything after SELECTALL then add
QQ
ZA
to the end of the file to see the whole drawimg.
Then create a second file containing
QQ
CP
QQ
PS
210,50
QQ
ZA
I called this file 'copy.txt'.
Copy everything in this file and paste it into the command line. Not very satisfactory, but at the moment it is all I can think of.
Manually selecting everything in the drawing seems almost instant on such a small drawing, but pasting is many times faster.
I tried adding multiple QQ's to the file, multiple blank lines, and other commands to try and slow it down, but it didn't work.
Perhaps you can think of a better solution.
Regards
riverbuoy
ZA
CP
PS
210,50
ZA
Regards
riverbuoy
- Premier Member
Hi All
I think I have a solution, well hack really, I used saveas command to pause
input and all you do is cancel... One thing I have noticed is that commands for
LINES.ARCS,CIRCLES can be executed without any problems..So I will continue
with my stand alone project
commands that take a while to capture screen contents like SELECTALL
make the lines underneath skip... in AutoCad you can use:-
LINE
0,0
'DELAY 2000
'REDRAW
5,0
'DELAY 2000
'REDRAW
5,5
'REDRAW
'DELAY 2000
ETC
Files Attached for testing..
Cheers
John
PS I had to add .txt to upload .scr file?
PPS I'm not giving up yet...
LINE
0,0
'DELAY 2000
'REDRAW
5,0
'DELAY 2000
'REDRAW
5,5
'REDRAW
'DELAY 2000
ETC
Cheers
John
- Qcad Run Command with Hack.txt
- (345 Bytes) Downloaded 562 times
- DELAY.SCR.txt
- (87 Bytes) Downloaded 561 times
- Premier Member
Hi All
Ok the project I'm working on is to generate sheet metal parts and add views
like this example this is of a sheet metal tray 150x100 with 25mm outside folds
2mm thick with a Kfactor of 0.41 ( Kfactor = Bend Allowance )
The user will have options to type in size in X & Y fold height , material thickness and Kfactor
the text will then be generated in a combobox in the program with a click button to copy to clipboard.
for Linux users they will need to select the text in combobox not sure if the copytoclipboard works for Linux...
Sample of what can be done, program demo will follow when I've sorted out a few things, want to add Cone development
u-bracket development etc...
I wish I knew how to use javascript it could then be easily added into qcad rather than being a stand alone app
Sample attached of what it can do,,,
Cheers
John Hyslop
PS Bend Lines Are added too...
Cheers
John Hyslop
- Blank 150x100x25x2mm0.41Kfac.txt
- (1.35 KiB) Downloaded 573 times
- Premier Member
Oops
Missed last inside arc centre
Should be same as previous arc
Cheers
John Hyslop
Cheers
John Hyslop
- Premier Member
Hi All
Could some users on here test this please, I've had 1 private message saying it fails on 1st line command,
I cannot myself recreate this, I've tried 32 bit versions, Linux versions, community versions all in a virtual machine
and this works..?
Simply copy and paste text into command line in QCAD and it should draw 2 views and a developed blank..
If I have lots of people saying it doesn't work I'll drop my project, but for now I'm working on it, sheet metal tools..
Thanks for any help and feedback ,
Cheers
John Hyslop
and this works..?
Cheers
John Hyslop
- (1.35 KiB) Downloaded 581 times
Metric guys have to use the comma and semicolon, so it fails.
But only after the first 2 coordinate pairs and even those pairs are not drawn correct.
I tried a new and clean installation but still the comma is persistent.
Last time I reported this:
https://qcad.org/rsforum/viewtopic.php? ... hilit=mess
It wasn't a really 'clean' install, I could detect settings or preferences in the installer and on initial run of Qcad that have to come from some former preferences while any trace of QCAD was deleted.
Like: the installer is in dutch while my system is in english.
The initial run: In dutch, it proposed mm, the comma. I always kept my OS and Apps in english. Never preferenced dutch.
All Qcad UI fonts are now Helvetica.ttf while I installed that font only about a month ago as a test.
https://qcad.org/rsforum/viewtopic.php? ... ica#p28587
Even better: it isn't a system font, a copy of the ttf was set in the QCAD font folder that didn't exist anymore on re-install.
I still have that font, in a ZIP and I don't intend to use it.
And there are more of such ghost preferences.
It still is a big mess in Andrews words.
This is the command history after pasting:
And it looks like: Regards,
Command: new
Command: qq
Command: line
Command: -72.85857864,-71.42964564
Command: -72.85857864,-47.85857864
Unknown command or invalid coordinate or value: "-96.42964564,-47.85857864"
Numbers may be entered as: "3,142"
Coordinates may be entered as: "1,234;1,234" (absolute) or "@1,234;1,234" (relative) or "10<278,873" (polar) or "@10<278,873" (relative polar)
You may change the number / coordinate format in the application preferences.
Unknown command or invalid coordinate or value: "-96.42964564,47.85857864"
Unknown command or invalid coordinate or value: "-72.85857864,47.85857864"
Unknown command or invalid coordinate or value: "-72.85857864,71.42964564"
Unknown command or invalid coordinate or value: "72.85857864,71.42964564"
Unknown command or invalid coordinate or value: "72.85857864,47.85857864"
Unknown command or invalid coordinate or value: "96.42964564,47.85857864"
Unknown command or invalid coordinate or value: "96.42964564,-47.85857864"
Unknown command or invalid coordinate or value: "72.85857864,-47.85857864"
Unknown command or invalid coordinate or value: "72.85857864,-71.42964564"
Unknown command or invalid coordinate or value: "-72.85857864,-71.42964564"
Command: qq
Command: line
Command: -73.21482282,-47.85857864
Unknown command or invalid coordinate or value: "-73.21482282,47.85857864"
Command: qq
Command: line
Unknown command or invalid coordinate or value: "-72.85857864,48.21482282"
Unknown command or invalid coordinate or value: "72.85857864,48.21482282"
Command: qq
Command: line
Unknown command or invalid coordinate or value: "73.21482282,47.85857864"
Command: 73.21482282,-47.85857864
Command: qq
Command: line
Command: 72.85857864,-48.21482282
Command: -72.85857864,-48.21482282
Command: qq
Command: za
Command: qq
Command: line
Unknown command or invalid coordinate or value: "-75,125.42964564"
Unknown command or invalid coordinate or value: "-75,146.42964564"
Unknown command or invalid coordinate or value: "-73,146.42964564"
Unknown command or invalid coordinate or value: "-73,125.42964564"
Command: qq
Command: line
Unknown command or invalid coordinate or value: "-71,123.42964564"
Unknown command or invalid coordinate or value: "71,123.42964564"
Command: qq
Command: line
Unknown command or invalid coordinate or value: "-71,121.42964564"
Unknown command or invalid coordinate or value: "71,121.42964564"
Command: qq
Command: line
Unknown command or invalid coordinate or value: "73,125.42964564"
Unknown command or invalid coordinate or value: "73,146.42964564"
Unknown command or invalid coordinate or value: "75,146.42964564"
Unknown command or invalid coordinate or value: "75,125.42964564"
Command: qq
Command: ar
Unknown command or invalid coordinate or value: "-71,125.42964564"
Command: 4
Command: 180
Unknown command or invalid coordinate or value: "71,125.42964564"
Command: 0
Command: qq
Command: za
Command: qq
Command: line
Unknown command or invalid coordinate or value: "150.42964564,50"
Unknown command or invalid coordinate or value: "171.42964564,50"
Unknown command or invalid coordinate or value: "171.42964564,48"
Unknown command or invalid coordinate or value: "150.42964564,48"
Command: qq
Command: line
Unknown command or invalid coordinate or value: "148.42964564,46"
Command: 148.42964564,-46
Command: qq
Command: line
Unknown command or invalid coordinate or value: "146.42964564,46"
Command: 146.42964564,-46
Command: qq
Command: line
Command: 150.42964564,-48
Command: 171.42964564,-48
Unknown command or invalid coordinate or value: "171.42964564,-50"
Unknown command or invalid coordinate or value: "150.42964564,-50"
Command: qq
Command: ar
Unknown command or invalid coordinate or value: "150.42964564,46"
Command: 4
Command: 90
Command: 180
Command: 180
Command: qq
Command: za
Command: qq
Command: qq
- Premier Member
Interesting CVH
I myself use the Metric system and this doesn't happen in any version of Qcad that
has been released over the last 2 years.. community version ok too..
As I said tried in linux, windows 7 32 bit, windows 10 64 bit.. ??
I'm dropping it.... and going to look at javascript version of some ideas I have..
I can't see it be harder to learn than Visual Basic.. but it's still a big learning curve
Maybe in Europe the settings are different ....who knows....
I've only ever used commas for input co-ordinates, like all other cad systems ?
it looks like the line command isn't being recognized on your version for some reason?
the input to command line is correct , when would you use a semicolon ";" in coordinate input?
Try Typing manually
Line
0,0
0,100
And I bet it draws a line...
Thanks for the input..
Cheers
John
It doesn't fail for me?
Try Typing manually
Line
0,0
0,100
Cheers
John
- Premier Member
Setting straight out of the box...
- Qcad 3-24-3.jpg (282.47 KiB) Viewed 14027 times
- Metric.jpg (67.24 KiB) Viewed 14027 times
- Premier Member
Hi CVH
See Screenshot.... I did do some investigation and the Default settings for Qcad are "," Comma
But there is an option to choose semicolon ";" why anyone would do this though has me puzzled..
maybe testing code from other programs...?
Cheers
John
Cheers
John
- Commas.jpg (275.56 KiB) Viewed 14019 times
A) Bad example because '0,0' in Europe is simply zero even if you add tons of the literals '0' after the decimal separator and '0,100' is simply 1/10mmJohn Hyslop wrote: ↑Wed Aug 05, 2020 7:59 amTry Typing manually
Line
0,0
0,100
B) Yes a line and NO, not correct.
It draws a line from the relative origin, 0.1mm long, at an undefined angle.
Trows an error about the number format and hangs there waiting for a next point.
(I say undefined angle because that is not persistent in numerous trials, on numerous new drawings, with numerous reboots)
What will work, and only as this for pairs:
Line
0,000;0,000
0,000;100,000
Altough position (0,000;0,000) is displayed as '0.000;0.000' in the Status Bar & position (0,000;100,000) as '0.000;100.000'.
Altough the property editor displays the numbers eg. for Start- & Endpoints with a point as decimal separator.
Altough the dimension formatting is perfect.
See the screengrab in the reffered links.
Andrew calls it a mess and he is aware of that issue.
And again, everything on a fresh installation 8 hours ago.
Simply trying to help someone with inserting a library item corrupted my Qcad.ini
https://qcad.org/rsforum/viewtopic.php? ... 988#p28988
Because our decimal separator is a comma, so we can not use a comma as list separator.John Hyslop wrote: ↑Wed Aug 05, 2020 9:22 amI did do some investigation and the Default settings for Qcad are "," Comma
This is common for most of our Apps, remember the XLS to transform Hatch pattern files.
- Premier Member
Hi CVH
If I do this
Line
0,000;0,000
0,000;100,000
I get a Zero Length Line?
Anyway.. looking at javascript.... may as well get into it..
Cheers
John
If I do this
Line
0,000;0,000
0,000;100,000
Cheers
John
CVH wrote: ↑Wed Aug 05, 2020 9:30 amAndrew calls it a mess and he is aware of that issue.
Hmm, Andrew never mentioned that to me .... and a library item corrupted your QCAD.ini. LOL
@John - I like your script
And then there are apps out there which gives the user the power to chose the separator by himself - like MS-Excel. Hmmmm, would it not be great if QCAD could do that too ....? Or maybe QCAD already can do it.
Yes Husky,
You got the PM to explain how to insert a new folder if adding an item doesn't show.
After removing the trials for the help I gave, a next reboot failed.
With the debugger I narrowed it down to LibraryBrowser.js
That is a precarious thing in conjunction with library_3_0_0_9.db that sits in C:\Users\Admin\AppData\Roaming\QCAD
You can not alter or rectify this manually.
So I reset my configuration and removed/renamed my QCAD3.ini
Then the library update on boot stalled with all blank entrys for the libraries and a blank progress bar.
After an hour I decided to quit that, reset my configuration again and removed library_3_0_0_9.db too.
Now Qcad failed to boot completely even with the debugger on.
Left with no options I wiped everything as once before.
It took only one day, I get good at this and I have an overview where the remaining traces could be.
Downloaded the last art and installed it.
At that point I saw the ghost preferences I mentioned.
Why the hell 'Helvetica' is used I can't explain, it isn't even a system font.
Why Qcad sets defaults to Dutch, mm, comma on a clean install and where it gets these defaults is a mystery.
Its running again. I'll keep away from the library browser for now.
In QCAD3.ini under [LibraryBrowser] the SourceList spells something as @Variant(...gibberish...)
That used to be a simple list:
C:\Program Files\QCAD\libraries, C:\Program Files\QCAD\Downloaded
And I see a lot of those @Variant(...) entries.
One thing I learned from all that: The max items for all the libraries is hardcoded to 10k.
