Duplicate and scale
Bertrum
Duplicate and scale
Post by Bertrum » Thu Jul 09, 2020 10:55 am
Hello I am using version 3.24.3.0 on a Mac. I use QCAD to draw model aircraft plans. I am trying to find a way to take a wing rib and duplicate it and scale it at the same time to create all the ribs for a tapered wing. I hope you understand what I'm trying to do. I have attached a top view of wing ti illustrate. I have not drawn the rib profiles yet.
Screenshot 2020-07-09 at 10.51.57 am.png (1.04 MiB) Viewed 2349 times
Tim
Re: Duplicate and scale
Post by andrew » Thu Jul 09, 2020 12:02 pm
Perhaps through morphing? Just a thought as I've solved similar problems with the morph tool:
https://qcad.org/en/tutorial-morphing
Bertrum
Post by Bertrum » Thu Jul 09, 2020 12:17 pm
Thanks, that looks promising.
Post by CVH » Thu Jul 09, 2020 12:41 pm
The problem will be that an offset of an airfoil shape is not a new correct airfoil shape.
Although it looks that way for us. :wink:
I don't know if morphing will level out the differences good enough.
A little off has a huge impact.
There are calculators for that.
