Compabilitty whit Cypecad
Roberto Vid
Post by Roberto Vid » Tue Jul 07, 2020 9:07 pm
Hi all,
I work with the Cypecad software, and I'd like to know If DWG of QCAD drawing would be compatíble with Cypecad software. When I use Cypecad software I need to get automatically the drawing from QCad ( AutoCAD ).
Regards
Re: Compabilitty whit Cypecad
Post by CVH » Tue Jul 07, 2020 9:33 pm
Don't know. Qcad is 2D.
Why not try it the otherway around and see if Qcad can handle your DWG/DXF?
Its an easy install, and there will be almost no trace once you delete the install folder.
Qcad is Qt based so I think you are 'save' if that is the hurdle.
Post by Husky » Tue Jul 07, 2020 10:35 pm
Don't understand why you ask this question ....
You are already a QCAD Pro user, seems you have access to Cypecad and Autocad - why you are not testing the compatibility by yourself?
Roberto Vid
Post by Roberto Vid » Tue Jul 07, 2020 11:36 pm
Hi all,
Thanks for quick reply
I still no working with my new CYPECAD ,( its a
concrete structure calcule software), probably tomorrow I'll be using that. At the instruction of the software says be compatible whith Autocad and others software, but no says nothing about QCAD, so I decided to ask here, but I think it'll work. I Hope.
Thanks all
Regards
