[Solved] Can't Read Text After Export to PDF
Cold-Rite
Post by Cold-Rite » Fri Jul 03, 2020 2:59 am
Morning all,
Untrained Noob here.
I am having an issue where I can't read the text on a plan after I export to PDF.
When viewing normally, all text is readable and easy to understand. I export to PDF and the lineweight of all the text changes making it illegible.
I have attached a "Pre Export" and a "Post Export" screenshot for your reference.
Appreciate your help and patience.
Cheers
Moses
Pre Export
PRE Export to PDF.png (196.63 KiB) Viewed 2245 times
Post Export
Post Export to PDF.png (206.52 KiB) Viewed 2245 times
Re: Can't Read Text After Export to PDF
Post by Husky » Fri Jul 03, 2020 4:59 am
looks like just a print setting doesn't suits the requirement - please refer to this print tutorial to see what could it be:
https://qcad.org/en/tutorial-printing
If you still face print issues after studying the print tutorial please attache the drawing to this topic for further investigation. Thanks.
Cold-Rite
Post by Cold-Rite » Fri Jul 03, 2020 10:24 pm
Boom! That did it. Thank you.
