[solved] Differtent print format between 3.23 and 3.24 version
RaNoPlus
Post by RaNoPlus » Wed Jun 24, 2020 9:03 am
I have a question about te printing (into pdf).
I just printed a drawing in the newest version and the pdf is "smaler" than in the old version (3.23). A drawing (same lay-out) on A0 was in 3.23 printed into pdf as it should be. So on A0. In the newest version (3.24) the drawing seems to be smaler (like on a A1) so it doesn't fit. I DIDN'T change any settings of my printer or anything else (paper settings etc). As you can see the settings of my printer are the same. The only difference is the version of Qcad. See attached pdfs and dwg. Do you know where the problem is?
Thank you for your answer.
Radek
1306081-5 External LPS AMS12 REV6 23-06-2020.dwg
(3.14 MiB) Downloaded 22 times
Print All v3.24.9.pdf
(7.11 MiB) Downloaded 25 times
Print All v3.23.pdf
(4.05 MiB) Downloaded 21 times
Print window 3.24.9.png (1.08 MiB) Viewed 455 times
Print window 3.23.png (1.25 MiB) Viewed 455 times
Re: Differtent print format between 3.23 and 3.24 version
Post by andrew » Wed Jun 24, 2020 9:14 am
I can tell that the two PDF's have the exact same paper size:
118.89 × 84.11 cm (A0)
Are you referring to something else? Or does the problem only occur when printing the PDFs?
Post by CVH » Wed Jun 24, 2020 9:35 am
What I can see is that:
Equal pdf paper size.
Print_window_3_24_9.png >> Manco some dims
The 24_9 pdf >> Manco the same dims and the border
The png's differ in size.
What are you printing?
The current view?
On paper, To pdf?
More questions than answers, sorry.
RaNoPlus
Post by RaNoPlus » Wed Jun 24, 2020 1:48 pm
I only make pdf's. Also when I plot them. So I can't tell you if this happen also when I plot in paper. Strange is that one drawing fits A0 as it should but the other not. Both formats are the same.
RaNoPlus
Post by RaNoPlus » Wed Jun 24, 2020 1:53 pm
The current view?
On paper, To pdf?
The .png files are just to let you see the printer settings are the same. It's about the drawings in PDF. One is fitting correctly on A0 but the other not. I am using the same settings, it's exactly the same drawing and I didn't make any changes of my printer settings. There were also no updates om MacOs. So I don't know.
I am printing the same view (LPLAMS12 all). You can see it on those .png files.
I am printing to pdf. As always. See also my reply to Husky.
Post by CVH » Wed Jun 24, 2020 2:40 pm
The .png files are just to let you see ...
We know, but the pdfs are about exactly the same in size, the design on it too.
I was just listing the things we could see.
There is missing somewhat on the later version ...
Well, I trust Andrew to export his art to pdf ... bugs are dealt with ... :wink:
Did you try XD?
Export to pdf.
'Print To' is from your printer driver.
RaNoPlus
Post by RaNoPlus » Wed Jun 24, 2020 9:06 pm
Did you try XD?
Export to pdf.
Yes, I tried XD, see attached file. It's still not printing this drawing on A0 correctly.
1306081-5 External LPS AMS12 REV6 23-06-2020.pdf
(7.95 MiB) Downloaded 20 times
RaNoPlus
Post by RaNoPlus » Wed Jun 24, 2020 9:40 pm
Now I was playing with all the versions I have and find one interesting thing. Version: 3.24.3.0 (3.24.3) is working fine! So I think it's the newest version (snapshot) which is not working correctly- talking about pdf print.
Post by andrew » Wed Jun 24, 2020 9:55 pm
I'm afraid I still don't follow. The PDFs you posted from QCAD 3.23 and 3.24 are exactly the same size (A0). What exactly is wrong / the problem? Why do you think one will not fit on A0?
RaNoPlus
Post by RaNoPlus » Wed Jun 24, 2020 10:28 pm
Not really, one drawing is complete with the border, title block, the other NOT. I have played with the drawings and I see now that the border and title blocks are in Defpoints layer (non printable) . This is the answer ( I think).
The last question remains, why it's wel printed in 3.23 version when it's the same drawing.
Post by Husky » Thu Jun 25, 2020 12:32 am
Hi guys! If your plan was to confuse me ...................... you won!
The issue is reproducibly.
The reported issue has nothing to do with the printed size of the drawing!
The issue is: Paper_Space (LPLAMS12 all) printed to pdf shows or shows not border, title block etc. within different QCAD versions ...
... it looks like it was working till 3.23.0.2 ...
... back to Andrew. :wink:
Post by CVH » Thu Jun 25, 2020 5:32 am
The issue is reproducibility.
Correct. Still: reported was 'format' as of size.
We asked for that 3 times.
Up to Wed Jun 24 it was size and manco's were discarted over 'fits a A0'.
Both are perfectly A0!
IMHO A1 is half a A0, if it won't fit a A0 how could it rather fit a A1.
On Wed Jun 24, 2020 11:28 pm that changed.
Now we are taking about what is actually on the paper.
Post by andrew » Thu Jun 25, 2020 7:54 am
Yes, I can see that. So if I understand you correctly, the paper size is not the problem at all but visibility of a part of the drawing? Please confirm, as above you were talking about the drawing not fitting on A0 and being a different size (A1). Quote "the drawing seems to be smaler (like on a A1) so it doesn't fit". Are these two separate issues?
That's the answer to a different question: the question why some things are missing in one PDF. Never put anything on layer "Defpoints" - it's a format internal layer and always non-printabe.
Support for non-printable layers was added in QCAD 3.24.
RaNoPlus
Post by RaNoPlus » Thu Jun 25, 2020 11:08 am
Hi Guys,
I think this issue is done now. It's the 'defpoints thing'. As I understand this was added in 3.24. So that's why there is difference between the versions (visibility of defpoints objects). Thank you for your replies.
Regards Radek
