Redraw command
NPD
Redraw command
Post by NPD » Mon Jun 22, 2020 1:51 pm
I'm new to QCAD. But I've used AutoCAD years ago, version 11,12. Is the a 'redraw' command in QCAD? Or is it not necessary anymore?
Thanks.
Re: Redraw command
Post by Husky » Wed Jun 24, 2020 7:34 am
... Is the a 'redraw' command in QCAD? Or is it not necessary anymore?
Nope - you don't need it anymore. :wink:
NPD
Re: Redraw command
Post by NPD » Wed Jun 24, 2020 1:07 pm
Cool. Thanks.
Re: Redraw command
Post by CVH » Fri Jun 26, 2020 11:12 am
Andrew,
Entities order is recalculated on save/open.
'Send to back' will make this =(minimum-1) for all selected.
Reloaded you will get them renumberred from 0 - 1 - ...
The same goes for 'Send to front' ...
Can we get them renumberred without a redraw or a reload?
MO is manually.
MC is not the same solution as save /revert.
Re: Redraw command
Post by andrew » Fri Jun 26, 2020 12:25 pm
You'd have to script that:
- query all entities
- order by draw order (RStorage::orderBackToFront)
- assign new draw order
The order number is actually translated during save into the order in which entities are saved which matches the display order in DXF/DWG.
