Is there a way to change the color of the screen environment from the layout (paper space) to dark color? I have difficulty seeing with the defaut color.
thank you
Regards
(Solved) Change paper space color
- Active Member
Re: Change paper space color
Edit > Drawing Preferences > Printing > Colors > Background Color
Note that this will mean that you will also print in that color and export to PDF in that color.
