I'm editing a grafcet and I often need to wrap my text in a fitted box.
I'm resizing the box manually, depending of the text length.
How can automate this ?
Block And attributes doesn't fit my needs as the drawing in the block in static even if the content of the attribute is dynamic.
autofit boxed text
Re: autofit boxed text
Unfortunately, automatic text wrapping is not currently supported in QCAD.
ok. thanks for you answer.
Below Menu / Misc / Draw you will find a tool called "Draw Bounding Box". Not exactly what you are looking for but maybe it can help a little bit with your bounding task ...
How?
Select the text - launch the "Draw Bounding Box".
BTW: It works with a multiple selection and the "smart use of layer" and a few QCAD tools brings you close to "Automated ....
This example was done in less than 30 seconds.
How?
