[solved] main window opens with bottom below screen
jamby
Post by jamby » Wed Jun 17, 2020 2:36 am
Hi
Version:
3.18.1.0 (3.18.1)
Internet:
QCAD.org
Build Date:
Oct 4 2017
Revision:
24e23aa
Qt Version:
5.8.0
Architecture:
x86_64
Compiler:
gcc 4.8.1
CentOS Linux release 7.8.2003 (Core)
When I start up the program the bottom of the main window is below the toolbar at the bottom screen. I have tired several different methods to bring the bottom up. Alt-F8, windows button / mouse, etc.
Also the box in the center of the three selections in the upper right corner ot the main window is missing.
Is there a file that can be edited that contains the size of the window on opening?
Jim
Re: main window opens with bottom below screen
Post by Husky » Wed Jun 17, 2020 4:47 am
it's probably easier to start from zero than try to fix it. How to reset the QCAD configuration can be find in this tutorial:
Post by CVH » Wed Jun 17, 2020 6:04 am
Yes, and no: QCAD3.ini
That part isn't human-readable. :?
A reset will start from scratch as a first installation.
Easy when there is not a lot of customization involved.
I posted a gentle approach on how to reset placements of Widgets and Toolbars a while ago.
https://www.qcad.org/rsforum/viewtopic. ... 795#p26771
Give that a try before resetting the lot. :wink:
jamby
Post by jamby » Wed Jun 17, 2020 4:28 pm
Husky, CVH
After closing the current Qcad session then deleting the .config/QCAD/QCAD3.ini file when I started up Qcad it came back to normal screen size.
Thanks much
Jim
