Remove all dimension entities
I would like to remove all arrows with dimension from my DWG (bottom).
See DWG file and a screenshot below. Do you have any idea how to do this with command line ? Which option ?
If anyone has the answer I would be thankful
Debian 10
QCAD version 3.22.1
Debian 10
QCAD version 3.22.1
- ANGLET Ensemble des niveaux RDC à R+7.dwg
- (1.79 MiB) Downloaded 390 times
- Capture d’écran du 2020-06-11 09-31-07.png (117.37 KiB) Viewed 8049 times
- petevick
- Premier Member
Re: Removed arrow with dimension
from the menu Edit>Drawing Preferences click on Dimension Settings in the dialog box, then set the Arrow size field to 0, click on Apply
Pete Vickerstaff
Thanks but I would like to remove the dimension (line, arrow, value). I try to set all value to 0 but the line are always visible
Just to be clear: are you looking for a way to remove (delete) all dimension entities from the drawing?
View > Selection Filter
Choose "Dimension" as type and click the button at the bottom left to select all dimension entities: Then hit the Delete key or choose Edit > Delete.
@louis
Please note that QCAD is a 2D program. Your drawing has Z values all over the place. I assume it is converted from a 3D drawing.
I recommend to clean the drawing from all Z-values before you put more work in it with QCAD.
Re: Remove all dimension entities
Ok thanks, so I think it's impossible to do that with command line ? Or to keep all layer expect layer with name X or Y ?
I'm sorry I'm a developper I don't have any skills with this software, be understanding with my strange question
Not out of the box. Using the QCAD script interface, you would have to create a command line tool that does that.
See also:
https://www.qcad.org/en/tutorial-comman ... ol-scripts
Ok thanks for your answers !
Yes I see but I need to used command line
