I am new to qcad and I just did my first drawing
Now for the printout I selected a dedicated scaling (let's say 1:50). Now I want to printout the selected scaling on my PDF or printer. In addition I want to have the units beneath my dimensioning (e.g. 130.0 mm) - right now I have only the numbers without units.
Any help would be great!
Added scaling and units to the printout
Re: Added scaling and units to the printout
I think the answers to your questions can be found in this topic and tutorial:
https://qcad.org/en/tutorial-printing
https://www.qcad.org/rsforum/viewtopic. ... bel#p27134
gnimor,
That are two different questions.
May I remind you on the 'Forum rules' displayed at the top of the forum topic.
(In red!)
I hope that you get things resolved with Husky's replies.
The learning curve is a bit steep in the beginning, we all know that.
But it is similar as the pandemic curves, it flattens out.
Happy drawing, keep it save.
(In red!)
@Husky: Thanks for your answer - and yes it was my fault to add two question in one posting. Sorry for that.
Regarding the scaling - I think this was no problem the scaling was fine on my printout. My problem was that the current scaling setting is not mentioned on the printout. So I want to see something like (1:50) at a corner of the printout. Otherwise I have to calculate this afterwards manually. Any idea?
Husky wrote: ↑Fri May 29, 2020 7:34 amHi,
How one present a drawing on paper depends greatly on the designer of the drawing.
On or with a scaled printout one should include the scale or provide another relation or notation.
Again, that is up to the designer.
There is no unique standard way to do this.
