[solved] Adding dimensions
LarryG
Post by LarryG » Sat May 23, 2020 6:48 pm
I am trying to add a dimension to a line. No arrows appear. It appears to create a new line. The tool I chose was dimension tools (wd) | horizontal (dh).
Platform: Windows 10
QCAD Pro version: 5.13.0
(Searching for similar issues in the forum did not locate this issue)
screenshot
island back design small.dxf
drawing file
(105.41 KiB) Downloaded 259 times
Re: Adding dimensions
Post by Husky » Sat May 23, 2020 7:12 pm
Looks like you have just to increase the Dimension "Text height" below:
LarryG
Post by LarryG » Sun May 24, 2020 2:59 am
Thanks, Husky. Now I can see the text, but nowhere do I see the measurement value. What am I missing?
BTW, the videos on YouTube look much different than the dimension function in my version.
LarryG
Post by LarryG » Sun May 24, 2020 3:04 am
Okay, it is working now. I bumped the text size to "2".
Thanks for the reply.
LarryG
Post by LarryG » Sun May 24, 2020 3:15 am
This is what it looks like now. Screen shot attached. Text size "1".
Can you apply dimensions, such as inches or mm, to the text?
Post by Husky » Sun May 24, 2020 5:47 am
Yes.
https://www.qcad.org/rsforum/viewtopic. ... bel#p27134
LarryG
Post by LarryG » Sat May 30, 2020 9:33 pm
Thanks, Husky. Got it regarding dimension terms.
BTW, the reason that the videos looked different ... I was not using the "aligned" measure tool. Much simpler now.
Appreciate the help.
