Solid fills
Iharch
Solid fills
Post by Iharch » Fri May 22, 2020 11:39 am
How can I change the transparency / intensity of coloured fills? I want to create subtler fills, can this be done?
Many thanks,
Iharch
Re: Solid fills
Post by CVH » Fri May 22, 2020 12:12 pm
The 'Alpha Channel' is not applicable on drawing colors.
It is only present for application colors.
See:
https://www.qcad.org/rsforum/viewtopic.php?f=32&t=6204
With a sort of a work around ...
There is an old feature request at:
https://www.ribbonsoft.com/bugtracker/i ... sk_id=1452
