I am having trouble with dimensions "rounding up" the dimension and cannot find anywhere to set the number of significant figures being displayed.
As a specific example: I am off-setting lines at 10.195mm apart, but when I dimension the drawing, the off-set is shown as 10.2mm, i.e. it has been rounded up.
So how do I get the dimension to show 10.195 instead of 10.2?
Setting Number of Significant Figures for Dimension
Re: Setting Number of Significant Figures for Dimension
Hi Kevinti28,
To change the precision in new drawings, go to 'Edit->Application Preferences'. Under 'Defaults For New Drawings' choose 'Dimension Settings' and change the precision.
Regards
riverbuoy
To change the precision in the current drawing, go to menu 'Edit->Drawing Preferences'. Under 'Dimension' choose 'Dimension Settings'. Scroll to the bottom, and choose 'Precision' under 'Linear Dimensions'. Change the precision to 0.000.
Regards
riverbuoy
A very resent post would be:
https://qcad.org/rsforum/viewtopic.php?f=32&t=7125
Continued from:
https://qcad.org/rsforum/viewtopic.php?f=76&t=7104
Also search for keywords:
- Dimensions
- Preferences (Application & Drawing)
CVH.
Continued from:
- Dimensions
CVH.
Thank you for your help, I knew there had to be a setting somewhere! Couldn’t find it in the manual, but as usual the forum came up trumps....
