[solved] Bitmap export ignores plottable status?
- ryancousins
- Premier Member
I've noticed when I export a .png of a drawing, any layers I had specified as not plottable are still visible in the image file. No big deal either way since I can just hide the layer before exporting. I'm just curious is this was by design to not match the output behavior of a pdf or printer. I didn't want to post this under the troubleshooting category as it might totally be an intended behavior.
Re: Bitmap export ignores plottable status?
Yes, intended behavior. Plottable refers only to printing on paper or pdf.ryancousins wrote: ↑Tue Mar 24, 2020 3:46 pm... I'm just curious is this was by design to not match the output behavior of a pdf or printer. I didn't want to post this under the troubleshooting category as it might totally be an intended behavior.
Yep - that is how it works ...ryancousins wrote: ↑Tue Mar 24, 2020 3:46 pm... No big deal either way since I can just hide the layer before exporting.
Re: [solved] Bitmap export ignores plottable status?
You might also want to have a look at layer states which might be more appropriate to store different layer states for printing, bitmap export, etc.:
https://qcad.org/en/tutorial-working-with-layer-states
