Is there a way to specify the width of your polyline BEFORE you start drawing, so that it draws at the width you specify 'while' you're drawing it? Right now I only see a way to go to the properties of the polyline AFTER the line is already drawn and then select global width. Perhaps I could do this as specified in a layer? Any assistance would be very much appreciated. Thank you.
[solved] View Polyline width while drawing it
Re: View Polyline width while drawing it
haha....ok. Thank you Andrew. Could I add this to the suggestion list then? Thanks for the reply.
