prepare file for laser cut
ivanm
Post by ivanm » Wed Jan 29, 2020 7:33 pm
Hello. I draw sketch and i want to cut it by laser in special firm.
But many lines is dublicated in my sketch.
How can I clear my sketch from dublicated lines???
PS: I tried to use "Modify->Detection->Detect Dublicates", but it helps only 20% of all.
I also tried to use special script for laser cut preparing "https://github.com/zippy84/lc-qcad" script. But I cannot install it.
after "Take the zip-file in the dist directory and unpack it in scripts/Misc/Modify of your QCAD installation. If neither Misc nor Modify exists, create them!" - there is no "Misc > Modify > Laser cutting formatter." in my meny.
So. Is there a simple metod to modify sketch for laser cutting????
My file is attached to this message
zakaz1.dxf
(854.66 KiB) Downloaded 327 times
plaatjesprater
Re: prepare file for laser cut
Post by plaatjesprater » Thu Jan 30, 2020 5:48 pm
There is a special function to do this: Modify > Detection > etc. This works specially for exact copies. If there are also overlapping lines who are not exactly doubled it won't work. Those lines you have to delete manually. In important drawings I sometimes try every line, just to be sure. If you work carefully enough you can simply delete layers with support lines.
a good design is like love at first sight
system: win10 HE, i7 266GHZ, 32Gb RAM, Geforce RTX 2060, qcad: 3.23
Post by CVH » Thu Jan 30, 2020 10:54 pm
Try:
https://qcad.org/rsforum/viewtopic.php?t=6654
and related topics from the same member.
Maybe I have some time to spare to look at your file.
The method that works best is to let Qcad search for continuous strings.
Isolate them, recombining.
A good indicator that a section is fully closed and simple is trying to hatch it.
Find Duplicates is specialized in very equal entities and not if the match is partially.
Post by CVH » Fri Jan 31, 2020 12:12 am
Did this quickly.
Started with Explode, Explode, Explode untill no more changes.
Detect Duplicates; dist tol 0,01; angle tol 1,00; both ignored.
Set those aside.
Used Poly from Segments to create strings and Poly from selected for the smaller closed forms.
Set the polys aside
Set the larger singles aside
-some are undetected doubles
-some are hidden behind longer entities
-some are just simple
What remained was very small, I call them spooks.
Set the Layer to pen max. bright yellow
There were Arcs and Lines both with zero length/radius.
Set those aside.
Nothing remaining
The next thing is to decided what to keep and bring back
.... :roll:
and ... restart all over
Exploding
Detecting doubles
Detecting zeros
After that it is straightforward. :wink:
BTW don't you need a spacing between the pieces ??
Regards
zakaz1-rev.dxf
(505.35 KiB) Downloaded 318 times
