Rotating Dimension Text
Is there a way to change the Dimension Vertical text to be rotated 90 degrees and be perpendicular to the dimension to keep all of the vertical and horizontal dimensions the same orientation?
Re: Rotating Dimension Text
I don't think so...
for the record: DL, DH & BV are all 3 of the kind 'Rotated Dims'.
That angle is the rotation angle.
You might enter a feature request...
I don't think so...
Hi CVH,
How does one put in for a feature request?
Here:
https://www.ribbonsoft.com/bugtracker/
First you have to start a new login.
It is separate from the forum or the site login.
