How to stop zooming run away?
Krischu
Post by Krischu » Tue Jan 07, 2020 6:16 pm
MacOS Catalina 10.15.2
QCad Pro 3.24.0.0
When I move the MacMouse just a bit the window zoom runs away quickly as if mouse events are piled up in a queue adn donÄt seem to end. This results in the drawing running very quickly out of sight in either direction - either zoom in or zoom out depending on which direction it has been started.
Is there a way to "tame" this mouse behaviour a bit? It seems to me that it either has changed with catalina or with the updated Qcad version. Cannot tell which is the cause since I changed both since last time working with QCad.
Christoph
Re: How to stop zooming run away?
Post by CVH » Tue Jan 07, 2020 7:48 pm
Maybe solved by searching for "mouse" :oops:
viewtopic.php?f=32&t=6317&p=23881&hilit=mouse#p23881
Cheers,
