MacOS Catalina 10.15.2
QCad Pro 3.24.0.0
When I move the MacMouse just a bit the window zoom runs away quickly as if mouse events are piled up in a queue adn donÄt seem to end. This results in the drawing running very quickly out of sight in either direction - either zoom in or zoom out depending on which direction it has been started.
Is there a way to "tame" this mouse behaviour a bit? It seems to me that it either has changed with catalina or with the updated Qcad version. Cannot tell which is the cause since I changed both since last time working with QCad.
How to stop zooming run away?
Christoph
Christoph
Re: How to stop zooming run away?
Maybe solved by searching for "mouse"
viewtopic.php?f=32&t=6317&p=23881&hilit=mouse#p23881
Cheers,
Cheers,
