[solved] Installed qcad on Centos 6
nelson
Post by nelson » Mon Dec 02, 2019 3:38 pm
I need help to install Qcad on a server under centos 6.
I followed the tutorial that you provided on your site but I encounter many errors related to Glibc.
It must be a week that I tried and I even went so far as to compile GCC 4.6 and GLIBC 2.14 but nothing goes.
Can you help me please ?
Here you can see the last error I can't solve by myself :
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libqcadecmaapi.so)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libqcadentity.so)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libqcadcore.so)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5Core.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libqcadgui.so)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libqcadoperations.so)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libqcadsnap.so)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5PrintSupport.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5Widgets.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5Gui.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5Script.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5ScriptTools.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5Network.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5Xml.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libQt5Svg.so.5)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libicui18n.so.56)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libicuuc.so.56)
#/home/manager/QCAD/qcad-bin: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/manager/QCAD/libspatialindexnavel.so)
#QCAD has unexpectedly quit.
#Please use the offscreen platform plugin for headless systems
#(without a running X11 server):
#/home/manager/QCAD/qcad -platform offscreen
Re: Installed qcad on Centos 6
Post by andrew » Mon Dec 02, 2019 4:39 pm
Which package did you download / install?
If you haven't already, can you try the QCAD legacy packages with Qt4 ("QCAD Professional 3.23.0 for Linux Legacy Qt4 64bit (tar.gz)", qcad-3.23.0-pro-linux-qt4-x86_64.tar.gz).
nelson
Post by nelson » Mon Dec 02, 2019 5:48 pm
I used the trial version pro 3.23.0 for 64 bit. I also tried the 32-bit version on a Centos 6 32-bit VM and it works except that I need it in 64-bit version :(
Post by andrew » Mon Dec 02, 2019 6:12 pm
Again, please do download the legacy package (under “All downloads”).
nelson
Post by nelson » Mon Dec 02, 2019 7:35 pm
I already did it, sorry I did not specify it earlier. Are you sure Qcad can run on CentOS 6 64bit ?
Post by andrew » Mon Dec 02, 2019 8:11 pm
Yes, the Qt4 package does. The regular package doesn't (as the glibc versions are not compatible).
nelson
Post by nelson » Tue Dec 03, 2019 12:04 am
Oh my god, are you serious, if I understand correctly, I have to install qt4 from qt-everywhere-src-5.10.1.zip and after that, Qcad will work ?
Post by andrew » Tue Dec 03, 2019 8:26 am
No, Qt is included in all QCAD packages. On a fresh installation of CentOS 6.10 64bit here, it's just download, install and run.
nelson
Post by nelson » Tue Dec 03, 2019 9:20 am
OK wait. I'll explain in more detail all the problems I've encountered because it's not just "download, install and run".
In the beginning I downloaded the .run file of the 64 bit version and it did not work. Then I took the .tar.gz file which is below "All downloads" and I had problems with Glibc like this one:
#./qcad-bin: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /home/manager/cad/qcad-3.23.0-trial-linux-x86_32/libspatialindexnavel.so)
#./qcad -platform offscreen
#In addition, you might have to override the default Qt style
#to prevent the loading of a native desktop style (such as GTK):
#./qcad -style plastique
I looked at the forums and the solution was to compile GCC 4.6 and move the "libstdc++.so.6.0.16" file to the "/usr/lib64" folder and create a link named "libstdc++.so.6".
After that I had the problem that I posted in the first post :
Currently I have version 2.12 of Glibc I tried to update to version 2.14 but I can not. I understand that the version of Glibc Centos are not compatible with Qcad but how to do without?
Post by andrew » Tue Dec 03, 2019 9:26 am
This still does not look like the 64bit package and also not like the Qt 4 legacy package. The package you're looking for is labelled "Linux 64bit Qt 4 tar.gz".
Here's a direct link to the trial version of that package:
https://qcad.org/archives/qcad/qcad-3.2 ... _64.tar.gz
This will extract into a folder called "qcad-3.23.0-trial-linux-qt4-x86_64".
Then cd into that folder and run QCAD:
cd qcad-3.23.0-trial-linux-qt4-x86_64
./qcad
If that does not work, please post the output here.
nelson
Post by nelson » Tue Dec 03, 2019 9:56 am
Thanks a lot, it works :D
But please, add more details on your tutorial because "If you get errors related to GLIBC, you'll have to install the Qt 4 legacy package (with "qt4" in the file name)." it's not precise at all.
Post by andrew » Tue Dec 03, 2019 9:59 am
Hmm.. I'll see if that can be made any more clear... Don't see how though. Anyway, thanks for letting me know it works as expected. Marked as solved.
