Page 1 of 2
[solved] How to print multiple Layout blocks to one PDF file
Posted: Sat Nov 09, 2019 5:08 pm
by MPN
I'm in a situation where I'm ready to print my architectural drawings. I have one master block and 4 layout blocks where I have layouted various viewports in different scales. I'm using A4 landscape in the Drawing Preferences -> Page. This all works really well. Great workflow.
I can select one Layout block at a time and print that layout (both to paper and to PDF).
Now I want to print my 4 layout blocks, but I can't find a way to print all 4 pages in to one PDF file or to print all 4 layout blocks to paper.
I can see the multi-page printing settings but that is not what I'm aiming for (I do not need to stitch drawings together; they are separate layouts).
Any help is appreciated.
Thanks.
Re: How to print multiple Layout blocks to one PDF file
Posted: Sat Nov 09, 2019 9:34 pm
by Husky
Correct - that is how the current QCAD version is indent to work.
You could use a workaround ....
To trigger an "all in one print" (pdf or paper) you could create an additional Layout Block. Name it e.g. "All layout blocks". Collect all content from the other Layout Blocks with the help of the clipboard (copy/paste). On this way you can create a multi page print which will print all paper prints or a pdf in one task.
Do I think that is a perfect solution? Nope - but the best what I can think of .....
Posted: Sun Nov 10, 2019 12:59 pm
by MPN
Thank you, will try that out and see how the workflow is.
Posted: Sun Nov 10, 2019 1:29 pm
by MPN
Yes that works for me. But it has some problems when I added more pages later.
I started out creating 1 column and 3 rows. Copy pasted my viewports and page headers. This worked well. I could now print to one file.
But then I wanted to add 2 extra pages for additional drawings. But the 2 extra pages was inserted _above_ my existing drawings so I had to move contents two pages up (by selecting and dragging them upwards).
I would expect new pages would be added after the existing ones. Should this be reported as a bug or is it by design?
Posted: Sun Nov 10, 2019 9:01 pm
by Husky
Yes, me too. It is counterproductive if you have to rearrange everything just because you added pages - especially if you print pdf's.
Should this be reported as a bug ...
Yes, I would second that.
... or is it by design?
I doubt that e_surprised
I encourage you also to file a "Feature request" to print multiple Layout Blocks at once. Yes I know that my workaround works but at the end of the day it is still a workaround.
To file a bug report or feature request please use this URL:
https://www.qcad.org/bugtracker
Note: You have to be registered for the bugtracker - your QCAD forum registration will not work there.
Posted: Mon Nov 11, 2019 8:48 am
The multipage feature is intended to print large drawings 1:1 on multiple pages to be stuck together as a poster. There is no "before" or "after" when adding pages. Adding more pages vertically will indeed expand the available paper space toward the top (Y+) which you might perceive as "before", but really is just following the direction of the coordinate system (X+ -> right, Y+ -> top).
Posted: Mon Nov 11, 2019 9:09 am
by Husky
That is the kind of insider knowledge what I don't have. :wink:
... ut really is just following the direction of the coordinate system (X+ -> right, Y+ -> top).
Question: If it just follow the coordinate system could a X+ -> right, Y- -> bottom cover the issue?
Posted: Mon Nov 11, 2019 11:02 am
by MPN
Thanks that explains the behavior. I can probably work around this by using a horizontal layout instead. For example use 1 row and 5 columns. Then adding more columns would be added 'after' the other pages.
Posted: Mon Nov 11, 2019 4:43 pm
by DougVW
I don't know if command line printing to PDF would be another solution for you. Andrew added multi-page output to Dwg2Pdf for QCAD v3.22.
Here's an example of a 3-page PDF export from Linux command line:
/usr/share/httpd/opt/qcad-3.22.0-pro-linux-x86_64/dwg2pdf -platform offscreen -a -f -block="Layout2,Layout3,Layout4" -m 5 -landscape -p "A4" mydrawing.dxf
Posted: Tue Nov 12, 2019 9:56 am
by MPN
Hi Doug,
Thanks. That is great info as well! That is actually what I need since the the Multipage setup is too slow to work with when having lots of pages.
I created this .bat file (I'm on Windows) that does exactly what I need: I can keep using single layout files and print by executing the bat file.
This might be useful for other users so pasting my bat file here:
@echo off
title Printing to PDF
rem This file can be placed in any folder but the following info needs to be set up for every drawing:
set file_to_print="C:/MyWork/CAD Drawings/QCAD/BuildingForCustomer.dxf"
set blocks_to_print="Layout1,Layout2,Layout3,SomeLayout4"
set qcad_installation_folder="C:\Program Files\QCAD\"
rem Set the working directory to the QCAD installation folder so qcad.exe can be found when running dwg2pdf.bat.
pushd %qcad_installation_folder%
call "dwg2pdf.bat" -block=%blocks_to_print% -f -k -landscape %file_to_print%
popd
Posted: Tue Nov 12, 2019 12:04 pm
by MPN
Hi Andrew,
What controls the order of the blocks written to the pdf when using dwg2pdf? It seem that the order specified in block="Layout1,Layout2,Layout3,SomeLayout4" gives the same result as block="Layout1,SomeLayout4,Layout2,Layout3"?
Posted: Tue Nov 12, 2019 12:53 pm
Blocks are sorted by name alphanumerically (see natural sort order).
The order of names in the -block parameter is irrelevant. Note that the string passed to the -block argument may contain regular expressions in which case the argument could not be used to define the order.
Posted: Tue Nov 12, 2019 2:17 pm
by MPN
Thanks. This design makes sense. But it seems it uses an internal string for the natural sort and not my defined block name.
I have these blocks:
2_Facader (*Paper_Space0)
3_Planer (*Paper-Space1)
4_Bad (*Paper-Space2)
5_Situationsplan (*Paper-Space)
They are printet to the pdf in this order:
So it seems QCAD is using the "(Paper-SpaceXXX) to sort the list?
Posted: Tue Nov 12, 2019 2:56 pm
Correct, since "*Paper_SpaceXXX" is the block name of those layout blocks.
This behaviour might change in a future version to sort based on the layout name for layouts. Or perhaps use the layout order since layouts (unlike blocks) do have an order value attached to them.
Posted: Tue Nov 12, 2019 3:38 pm
by MPN
Is there a way for me to change the numbering of the Paper_Space after they are created?
Yes the layout ordering would make sense, then the printed order would match the UI ordering
