constructing a round using a circle with two tangential points
TSG
Re: constructing a round using a circle with two tangential points
Post by TSG » Wed Sep 18, 2019 10:21 am
Post by CVH » Wed Sep 18, 2019 10:32 am
A former cad I used took into account at what side was pointed for tangents
so the user had control on the solution field.
Problems here are somewhat related:
https://qcad.org/rsforum/viewtopic.php?f=32&t=6490
Krischu
Post by Krischu » Thu Sep 19, 2019 8:37 am
Bug report created (see https://www.qcad.org/bugtracker/index.p ... sk_id=1942 )
Thomas
I saw that the bug already has been fixed. Hoping the fix already being included in the recent snapshot I downloaded that one (3.23.0.2). But the problem still exists (ct2.dxf) - husky's example).
Christoph
Christoph
Post by CVH » Thu Sep 19, 2019 8:50 am
Fixed but not included in an older snapshot
Read last comment:
https://www.qcad.org/bugtracker/index.p ... sk_id=1906
Post by Husky » Thu Sep 19, 2019 9:25 am
A already released version will never undergo a change. 3.23.0.2 was released 9 days ago.
With a bit of luck that fix will be implemented in the next available version. :wink:
