constructing a round using a circle with two tangential points
Krischu
Post by Krischu » Tue Sep 17, 2019 9:46 am
Bildschirmfoto 2019-09-17 um 10.44.08.png (180.35 KiB) Viewed 10527 times
How would I construct the small left circle. In this drawing it is just drawn so lá lá, not precisely constructed
One point is the endpoint of the line. The other two points are the tangent points of the two lines against the circle.
(N.B. the radius isn't known beforehand and the tangent points aren't either as well).
Christoph
TSG
Re: constructing a round using a circle with two tangential points
Post by TSG » Tue Sep 17, 2019 11:31 am
Thomas
Post by CVH » Tue Sep 17, 2019 11:33 am
You could draw a vertical construction line at the endpoint and use 3 tangent.
Post by andrew » Tue Sep 17, 2019 12:39 pm
Draw > Circle > 2 Tangents and Point:
https://qcad.org/doc/qcad/latest/refere ... /Circle2TP
Krischu
Post by Krischu » Tue Sep 17, 2019 1:06 pm
This doesn't seem to work. I'm asked for first line or circle, second line or circle and when being asked for "point on circle line" it doesn't snap at the endpoint.
@CVH: 3 Tangent works.
Christoph
Krischu
Thomas
What were you going to tell me? :)
Christoph
Post by Husky » Tue Sep 17, 2019 8:08 pm
The CT2 tool is built to solve the task easily without auxiliary lines.
Try this click order:
If it still not snap to the endpoint doublecheck your Auto Snap settings. End Points should be checked:
Post by CVH » Tue Sep 17, 2019 10:11 pm
Sorry, but when your point is at the bissectrice there is no solution....
And that should be the easiest one, one only!
TSG
Post by TSG » Tue Sep 17, 2019 10:17 pm
I agree. In this case with QCAD 3.23.0.0 and macOS Mojave the tool ct2 doesn't work.
When snapping to the endpoint or any other point on the line all solutions disappear.
I think it's a bug.
Thomas
Post by Husky » Tue Sep 17, 2019 11:36 pm
Interesting! :shock:
Guys - please do me a favor: After you mentioned it doesn't works (and it was flawless working for me!) I tested a bit and discovert something interesting. I won't tell you now the result ....
This dxf has two identical situation. Please test on each on them what I posted as solution for this task and tell me how it works for you. Thanks.
CT2.dxf
(110.61 KiB) Downloaded 469 times
TSG
Post by TSG » Wed Sep 18, 2019 9:06 am
e_surprised e_surprised e_surprised
#1 doesn't still work (no solution)
#2 works as expected (found 2 solutions)
Couldn't found any difference between the situations.
What's the reason for that?
Thomas
Krischu
Post by Krischu » Wed Sep 18, 2019 9:30 am
macOS mojave 10.14.6
Qcad 3.23.0.0
Invoking ct2 on example 1. results in the solution circles disappearing when selecting the endpoint (3.)
Bildschirmfoto 2019-09-18 um 09.22.41.png (18.27 KiB) Viewed 10441 times
Doing the same on example 2. results in showing the two circles for choice end lets choose the desired solution circle:
Bildschirmfoto 2019-09-18 um 09.21.39.png (22.47 KiB) Viewed 10441 times
Christoph
TSG
Post by TSG » Wed Sep 18, 2019 9:35 am
It's getting warmer...
When moving #1 down CT2 works.
Thomas
Post by Husky » Wed Sep 18, 2019 9:51 am
Thanks for testing!
Both situation are exactly the same (copy). Difference is only the location. e_surprised
CT2 behaves differently simply based on where it is used. Thomas, you expected already a bug - will you file a bug report?
Post by CVH » Wed Sep 18, 2019 10:00 am
Flaw depends on order reference line selection and selection place.
Flaw never 1 unique on bissectrice.
Flaw regions 0 instead of 2, 1 instead of 2 (drew quick and dirty).
Regions not strickt. Very tiny diffs may comply or not.
CT2_tested.dxf
(114.46 KiB) Downloaded 461 times
